1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
98Avenger Speaker Install Q's?
Old Dec 2, 2006 | 12:51 AM
Avenger1998's Avatar
Avenger1998
Default 98Avenger Speaker Install Q's?
(May have been asked but... )
I have a 98 Avenger ES that I am planning to get new Tweeters and Door Speakers for. It currently has all stock speakers. I have 2 main questions/concerns.
A) Does the dash need to be removed to access the Tweeters, or can I simply "plop" or pry the plastic cover off to access the Tweeters??
B) In order to install the Door Speakers, for my model of car, will I have to take off the door panel entirely, or can I again simply but carefully "plop" or pry the plastic cover off with a screwdriver to access the Door Speaker?? I'm hopeing it will be the simple way and not dismantleing my whole car.
-Thanks
Old Dec 2, 2006 | 01:20 AM
PappiDread6's Avatar
PappiDread6
Default RE: 98Avenger Speaker Install Q's?
The Dash speakers I honesty don't know I read somewhere around here you can pop them off with a flat head but again Im not sure. The door panel has 2,4,6 screws 1 behind the door handle in side the door grab underneath a thin plastic and 2 at both ends of the door. The speaker it selfs has 3 or 4 screws holding it. Also my speakers this thin "speaker cover" on it basically it was a round black pastic with a see-through screen it has sum brown stuff around it becareful cuz that stuff breaks off like breadcrumbs. I don't know if my wip is old or what but when I popped the door panel off both sides thats what hit the ground first. Oh yeah 1 more thing after you get the screws out then you can popped the door off.
Old Dec 2, 2006 | 04:41 AM
BSnyde's Avatar
BSnyde
you can just pop the grills out of the ones in the dash, i just put some infinity tweeters in my dask and used the bracket they game with (which fit perfectly in the little hole), then took the screen off the 2 inch speakers that are in the dash and covered them up.......
Old Dec 2, 2006 | 11:20 PM
Avenger1998
Alright so take the entire door panel off...not too hard. And for the tweeters, just pop off the grill cover...using a flathead screw driver or what? Because at the time I was testing the "pop off" idea and as I was trying to pry it off, I felt like I was going to break the tweeter grill...is that normal? Just pry a little harder and it should aventually come off? carefully?
Old Dec 3, 2006 | 04:13 PM
slhomer's Avatar
slhomer
I used a very small bent alan wrench, slid it threw the hole and pulled lightly with plyers and it cam right out
Old Dec 4, 2006 | 06:46 PM
PappiDread6
Aight aight I might hit that up on my day off cuz that front speaker on hte dash sounds booty.
