1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Dodge Avenger
Old Dec 6, 2006 | 03:10 PM
jrc3's Avatar
jrc3
Default Dodge Avenger
My Car Last week started ticking I cant realy tell whare its comming from it does it when you rev up the moter a bitwhile your ion park and while your going you have to get to about 3000 rpm and then it does it. i hane changed have the oil does any one hane ang suggestions?
Old Dec 13, 2006 | 11:49 PM
hckyplayer8's Avatar
hckyplayer8
Default RE: Dodge Avenger
well was there any shavings in the oil........r u sure u caped and pluged everything up securely when done.......can u try to guesstamate a certain spot where its comming from......was the timing belt ever replaced?.....more info plz
Old Dec 13, 2006 | 11:55 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
ORIGINAL: hckyplayer8
I smell a troubleshooter[sm=icon_rock.gif]
Old Dec 15, 2006 | 02:19 PM
jrc3's Avatar
jrc3
It was doing it before the oil chang and there was nothing in the oil no shavings it dosent sound like th etop of the engine it is more of the bottem of it. But im not shure if its in the engion. the belt was changed last year and it is sill good. if your going up a hill it will stop it only does it if you have the gas pettle pushed in a little you let off itll stop and if you push more itll stop. its just enuf to keep your speedthe same is how much.
