1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 Squeal Noise
Old Dec 14, 2006 | 11:43 PM
Hybird's Avatar
Hybird
Default 95 Squeal Noise
Just finished fixing the front driver side control arm which came apart and took out the axle.. got the car back together, but when we went to start it, it made a horrible squealling sound that i would have thought was coming from the belt or perhaps pulley. But it sounds like it is coming from the transaxle side of the engine in the front corner. It is hard to hear at idle, then gets progressively louder as the RPM's get higher. At first the car would idle ok, now trying it, it barely idles.. and tends to stall out after a few secs of running. Each time we started it up we only let it run for sort durations to aviod internal damage if that is the case.
The car went down doin about 10km around a corner. The front "straight" control arm came loose, the strut hammered the axle out and the lower subframe hit the ground. It ran fine when it was started right after.
Has anyone ever had a problem similar to this? its the 95 Avenger with the 2.5v6 engine auto trans.
Thanks
Old Dec 15, 2006 | 10:13 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: 95 Squeal Noise
How's the oil pan look? Have you checked to make sure that you have oil? Anyway, check your oil pan and make sure it didn't get dented in.
Old Dec 15, 2006 | 03:24 PM
Hybird's Avatar
Hybird
Ya I didnt quite check that out.. could be a crank throw hitting the pan. I'll look after work. And yes Checked trans and engine fluid both are good.
What does a spun bearing sound like?
Old Dec 16, 2006 | 06:28 AM
Hybird's Avatar
Hybird
Ok check eng pan, its fine. Now the damn thing just cranks. First I'm gonna put a bunch of gas in it, they start diagnostics.
does anyone know if this is a free wheeling engine? Could the timing belt be broken, and it turn over without wacking a valve??
Old Dec 16, 2006 | 06:47 AM
silvercoupe97
Uber Moderator
I'm pretty sure they are interferrence motors Things I would check...CPS, starter motor, perhaps distributor.
