burning oil...
title says it all. just noticed it on tuesday i think. sitting in a parking lot with my engine running for heat while waiting on a friend - repositioned myself and hit the gas pedal and revved, big puff of blue smoke blows past my car. rev it again to see if it happens again...nothing. so i wait another few minutes and rev again, sure enough - blue smoke.
what are the possible causes of something like this? can't be a bad ring or something cause then the smoke would be constant, right? kinda like it builds up at idle and then clears it out in a matter of seconds after accellerating. blah.
You know my venger did this to me around when i first bought her. I ran her hard and did a nice tune up new pcv valve and used the good ol seafoam on here she dont smoke any more. and it only would do it if i would sit at idle for a min or two then take off. it dont even hesitate to do it now
!!! Is your venger current with a tune up and oil change?? have you used seafoam or the other one "beleave it is mmc or something"
Joe
95 Es
!!! Is your venger current with a tune up and oil change?? have you used seafoam or the other one "beleave it is mmc or something" Joe
95 Es
makes sense. i just had my oil changed though. level is a little too high, which would make sense...considering it has nowhere else to go. dad won't let me change it myself as he's afraid of using jackstands/etc...as if it fell there isn't enough room under there for my body. i trust jackstands...
but anyways...had to take it to some car shop place to have it done. checked oil level today as i was already out there workin on her and it was a little bit over the maximum level. probably about 1/8th of an inch or so. could be the problem? if so...nothing really i can do about it except change the oil again?
