1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Transmission swap
Old Feb 25, 2007 | 04:17 PM
king_nothing's Avatar
king_nothing
Default Transmission swap
hey guys, well i got a 1995 dodge avenger, it was my moms but the transmission has gone almost completely out, its a 16 valve 4 banger base model avenger and its an automatic, my question is what all do i need to change it to a stick shift? money isnt a problem but i just need to know exactly what parts i need to make it work, thanks for the help.
--Seth
Old Feb 25, 2007 | 08:22 PM
MoPaul's Avatar
MoPaul
Default RE: Transmission swap
http://aseclub.net/forums/index.php?showtopic=21629from someone who has done it. wasn't me, so don't blame me
Old Feb 25, 2007 | 08:26 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
You'll need everything that is associated with a manual tranny...the pedals, shifter (everything associated with that), and the tranny of course. You may also want to get the manual car's ECU. You'll need to remove the TCU out of your car. I need to check if the fuel injectors are different between the two also. So, I'll have to get back to you on that.
