1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
abs light
Old Feb 28, 2007 | 12:30 AM
blackvenge34's Avatar
blackvenge34
Default abs light
ok my abs light is on does that mean i need new brakes or fluid or am i looking at bigger problems?
Old Feb 28, 2007 | 12:54 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: abs light
Take a look at your brake pads and how high does your e-brake go? Chances are, you just need to do some brake work. I wouldn't fill up your brake fluid either. If it's low, it can indicate a leak or low brake pads. If you system is pretty tight, I would say that the pads are just worn.
I've noticed my ABS light come on because of the e-brake pads needing changed. Remember, just because it's your Antilock Brake System light, it doesn't mean that it's not your braking system that causing it.
Old Feb 28, 2007 | 01:03 AM
blackvenge34
ok and truthfully i did notice a squealing noise going back to college it was squealing on and off and when it was squealing i taped the brake it stopped then today i saw the light maby that will help u diagnose it a little more
Old Apr 8, 2007 | 02:58 AM
sprman9's Avatar
sprman9
i know that my light has been on before after i got my transmission rebuilt. The place that did it broke a sensor. thats a possibility, but doesnt explain the squeaking. just an idea there.
Old Apr 8, 2007 | 03:26 AM
blackvenge34
i got all my brakes replaced but the light it on i think its a sensor but i havent had the time to check
Old Apr 8, 2007 | 01:33 PM
bad venge's Avatar
bad venge
Section Moderator
You might have to get the codes scanned my puter died according to a scan ,dealer wanted $1200 , Junkyard was $50
