1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
gauge cluster
Old Feb 28, 2007 | 02:03 AM
blackvenge34's Avatar
blackvenge34
Default gauge cluster
silver for your gauge cluster is it an eclipses or an avenger one like did they change it after 96 or so because i wouldnt mind haveing one like that with the oil level n all
Old Feb 28, 2007 | 02:12 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: gauge cluster
The Avenger gauge cluster had an oil pressure gauge, but I also had the V6 ES, I don't know for sure if that means anything though. I have an Eclipse GSX gauge cluster now and it also has an oil pressure gauge.
Old Feb 28, 2007 | 11:14 AM
blackvenge34
o so i cant pull one from a junkyard i cant just pop it in
Old Mar 1, 2007 | 10:58 PM
silvercoupe97
Uber Moderator
No sir. Well, you can, but it has to be from a same motor and tranny optioned car.
You can (but don't) swap a V6/I4 cluster around, but this will just give you the wrong speed, RPMs, fuel, water temp, and no oil pressure anyway (the oil pressure sending unit needs to be in your car).
If you really must have one, you can get an electrical aftermarket gauge(s) installed for one. They are nice to have though, so that you know you're motor isn't going to pop a gasket or lose lubrication all together.
IMO, go easy on yourself and get a gauge pod and an autometer oil pressue gauge and save yourself the worry of trying to fit a different cluster in . Besides, your car still needs the sender to get the pressure info so you might as well get an aftermarket gauge, it'll come with the sender
Old Mar 1, 2007 | 11:04 PM
blackvenge34
yea i was just curious actually my buddy gave me gauges dont know if it has the sender tho dont think so it came off his talon and not really sure but he might have had it because the gauge broke but any way i have a water temp one and oil one any idea how to install them?
Old Mar 2, 2007 | 10:18 AM
silvercoupe97
Uber Moderator
For the water temp, you can use the stock sender, but if you have a stock water temp gauge, you will lose it's functionality. For the oil temp, check the oil filter bracket for an 1/8" NPT opening (most likely plugged if you have one available)..I believe it's 1/8" NPT anyway. If you don't have one, you'll have to plumb a spot for a sensor. I say the oil filter bracket for the oil temp sensor because that's where I always seen them
Install is pretty straight forward, you'll usually have the lighting wires (red/black) and then the signal wire that comes from the sensor(s). You'll just need a gauge pod. You can get an A pillar or instrument cluster pod, both should be in the resource listing in the sticky.
Old Mar 2, 2007 | 11:11 AM
blackvenge34
ok and do i run all the wires through the firewall because my fire wall is really small and i have a power wire through it and 2 wires for my underglo switch
Old Mar 2, 2007 | 11:27 AM
blackvenge34
i see a whole bunch on ebay for cheap but i cant find one for an avenger will an eclipse one work
Old Mar 2, 2007 | 10:05 PM
silvercoupe97
Uber Moderator
Yup, run the wires through the firewall. There are a few spots that are already made, you just have to poke the wires through the rubber boots. You can also drill a hole, just make sure to seal it up with some RTV or something.
For the pods, you can use the Eclipse gauge cluster bezel but not the A piller pod, you'll have to use one for an Avenger/Sebring.
Also, just an FYI, there's someone that replied to your post over at the sister site about an Eclipse center console
Old Mar 3, 2007 | 03:20 AM
blackvenge34
yup i talked to them already unfortunatley i already found on and i thanked them lol so there is more then one spot ok the spot i used right now is the one it pops out in the left corner above and to the left a little of the clutch are there anymore in the area or where are some others located
