1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
lighting problems
Old Mar 2, 2007 | 06:45 PM
99GreenAvenger's Avatar
99GreenAvenger
Default lighting problems
i have a problem with my 99 and it sucks beacuse every time i open my door the lights dont come on so if its dark out i cant see anything but when i lock my car with the stock wireless key enrty the light blink to indicate that the car is locked im confusedoh and its (any of the doors)also my reverse lights dont come on either when i shift into reverseso if anyone knows how to fix this please tell me how
Old Mar 3, 2007 | 01:09 AM
MoPaul's Avatar
MoPaul
Default RE: lighting problems
the door switches seem to go rather often in these. poor design. i have replaced three and need to replace one more as we speak. have you checked the switches with any kind of continuity check?
have you checked the bulbs for the backing lights? if they are not blown, then i have not run into that one, sorry. could be a bad switch, but i don't know off-hand where that is. will check, but i believe the two problems to be unrelated.
Old Mar 3, 2007 | 05:40 PM
99GreenAvenger
hmmmmm i will check them for current that might be a problem im not sure but sometimes the door light comes on but thats like once a year lol also i have checked the light bulbs for the reverse lights they are not bad and they did work at one point i think yeah hey if you find anything post it please thanks alot mopaul
Old Mar 3, 2007 | 08:34 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Hey 99GreenAvenger, I'm going to have to ask you to use punctuations bud. It's hard to keep up with you and your thoughts without them.
The door light issue is a common problem, like MoPaul stated, it also happens to other cars too. You can take the door switches out and spray WD-40 down the opening. Once you get the oil down the opening, open and close the switch a billion times...no not really, just a lot, lol. These parts get very dirty and most of the time, the contacts just need to be cleaned. I've still got the original switches and every year, I remove and spray them down.
For the reverse lights, all you have to do is remove the bulbs and look at them. Are you saying that the wire that goes from one side to the other is still in place? Or that the bulb doesn't have some soot in it?
This is where you do a continuity check and I advise getting a Haynes or Chilton's manual for it.
Old Mar 4, 2007 | 05:38 PM
99GreenAvenger
Thank you! Guys it's been very helpful to me, ill go and try the things you said silver. By the way did you send the (how to remove the headlights instructions yet) see im new here and im not quite up to everyone else yet. Thank you again.
Old Mar 4, 2007 | 05:39 PM
99GreenAvenger
imintheaws@sbcglobal.net
Old Mar 6, 2007 | 06:23 PM
99GreenAvenger
thanks silver the wd-40 did the trick thanks alot!!! but i froze my butt off!
lol
Old Mar 7, 2007 | 09:07 AM
silvercoupe97
Uber Moderator
ORIGINAL: 99GreenAvenger
lol
Lol, sorry bro..it's cold here too. Temps have gone down into the 70's here in Hawaii....
lol, I'm kidding with ya
I'm glad that was your fix.
Did I email you with the headlight removal already?
Old Mar 7, 2007 | 01:35 PM
99GreenAvenger
yeah you sent it to me, already thanks for that too. But its more like 15 here or below lol
