1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
funny idle
Old Mar 17, 2007 | 06:03 PM
blackvenge34's Avatar
blackvenge34
Default funny idle
i have an idleing problem my idle is all over the place sometimes its at 1500 then bounces then drops to 800 it and all over the place doesnt go past 1700 tho and it did it befor i got the intake manifold gasket replaced it stopped not its doing it again
Old Mar 20, 2007 | 08:30 PM
spitfireflyr's Avatar
spitfireflyr
Default RE: funny idle
Make sure that your tps is connected. My car did it when i forgot to reconnect mine.
Old Mar 20, 2007 | 10:08 PM
blackvenge34
do you know where the tps is located?
Old Mar 20, 2007 | 11:11 PM
spitfireflyr
It's on the throttle body. There should be 2 electrical connectors. Make sure that they are both connected.
Old Mar 20, 2007 | 11:30 PM
Dodge Tech's Avatar
Dodge Tech
if the TPS is not connected u will get a check engine light right off the bat if u replaced the intake gasket and it went away for awhile then u have the same issue or another vac leak
Old Mar 21, 2007 | 05:16 PM
blackvenge34
yea my check engine light didnt come on is there an easy way to check or find the vacum leak
Old Mar 21, 2007 | 05:59 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
You can trying running the car and listening for it, but it will be difficult to hear over the motor, unless you know what it sounds like, a hiss. There are only a small amount of possibilities though. I suggest changing out your vacuum hoses. They're old and need to be changed anyway.
