1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
building a 420a
Old Mar 17, 2007 | 11:44 PM
99avenger420a's Avatar
99avenger420a
Default building a 420a
so if i was to keep my 420a i could put new pistons, rings, lifters and so on into it and run a turbo or would i need new cams and what not???
Old Mar 18, 2007 | 04:16 AM
blackvenge34's Avatar
blackvenge34
Default RE: building a 420a
i dunno if money wasnt an inssue i would do cams and maby cam gears since the motor is apart might as well in my opion
Old Mar 18, 2007 | 12:11 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
You won't need cams right off the bat but they are useful if you've got a big turbo. Cam gears are more useful IMO, because you can get the most out of the stock cams before you upgrade. The real question is, how big of a turbo will you get? How high do you plan on revving? That relates to the lifters. If you keep to stock rev limits, you won't float the valves.
If you want to go all out and as Bryan stated, if money wasn't an issue, get it all now, so you won't have to later. Just don't go with a small turbo, start with a 50 trim and you'll be happy.
If you go small, like a EVO316G type, just build the bottom end.
For FWD, I suggest big though, or you'll just burn through the gears before you get traction from a stop, but then you won't have enough umph up top.
So the simple answer would be a "no". You won't need the cams...that's just my .02.
Old Mar 19, 2007 | 05:23 PM
99avenger420a
k thanks i only plan on running in the 12-16psi range because it will be a daily driver but the stock 420a with full intake and exhaust just isnt doin it for me.
