89 dakota antifreez leak on head
Old Nov 1, 2010 | 12:07 PM
gman0913's Avatar
gman0913
Default 89 dakota antifreez leak on head
My son has an 89 dakota sport w/3.9 V6 automatic,on the head where the intake meets the head is a water journal that is just an open space where antifreeze is coming out the intake gasket doesnt seal seal it.
What can he do?
any feed back would be helpfull.
Thanks
Old Nov 1, 2010 | 01:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The gasket is blown, or improperly installed or the intake or the head is cracked/chipped or warped. Try replacing the gasket first.
Old Nov 1, 2010 | 01:16 PM
gman0913's Avatar
gman0913
Gasket only covers 3/4 of the hole just under the EGR valve that bolts to the intake on the right as you are looking at it
Old Nov 1, 2010 | 01:31 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Mabe you got the worng gasket.
Old Nov 1, 2010 | 01:51 PM
gman0913's Avatar
gman0913
the intake gasket i took off is the same exact on
Old Nov 2, 2010 | 07:59 PM
festerw's Avatar
festerw
There should be a bead of sealant in each of the 4 corners of the intake.
