Replacing brakes
Old May 18, 2011 | 02:14 PM
89newbie's Avatar
89newbie
Originally Posted by Crazy4x4RT
If your referring to me, post what ever you want. Its your thread. The forum is to help people, not confuse as per the other posts.
LOL not at all you are always imformative and quite willing to help. I was dissed down because of a comment from someone else in another post. Was a bad morning. SHaring here now what I found was the emergency brake lever was not reseating properly and hanging up the trailing shoe. THat forced both shoes out and then the front shoe hung on the slide on bracket next to the emergency brake adjuster. Also it caused the rear shoe to **** and destroy the insert held in place by the rear spring that the emergency adjuster rides on. It actually flattened the little cable and streached it enough that I had to get a new one. All this was cased by the tefflon( I guess tefflon), shield coating on the cable had broken and was causing the cable to not return and for the cable hang up.
Advanced had a listing for replacement so I ordered one and am going to pick it up now.
