New member intro
Old Nov 24, 2011 | 10:55 PM
AZ 360 Dakota's Avatar
AZ 360 Dakota
Default New member intro
My name is A.J. and I'm an ASE certified auto technician with my own shop in Mesa Arizona. I bought a '94 5.2 RWD Dakota back in August as a shop truck for $900. It needed a head gasket. Well, the head gasket turned into an engine because the previous owner left water in one of the cylinders too long and it got pitted. I could have rebuild it but I was looking at a lot more than a used engine. So since I had to replace the engine, why not upgrade? I found a 360 with 150,000 miles out of a '98 Ram on Craig's list for $450. It had Mopar Performance heads installed at 130,000 miles. What turned into a shop truck turned into my second love. My first is my 1988 Dodge Caravan that's turbo-charged running 17 lbs of boost with a best run of 15.3 in the 1/4 mile. I'm a regular on Turbo-Mopar.com. I've written about some of the upgrades on my truck over there in the "other vehicles" section, but I don't think they're appreciated as they would be over here. Some of the modifications I've done: 5.2 to 5.9 swap, installed '93 exhaust manifolds and Y-pipe and built a 3" exhaust from elbows and straight pipe, electric fan, converted the returnless fuel system to return, homemade oil catch can, cabin air filter, huge tranny cooler for towing. I plan on doing write-ups on the stuff I've done because when I was researching some of this stuff, this website was lacking the type of info I'm use to over on Turbo-Mopar.com so I hope I'll be able to help out others with information I was looking for but couldn't find.
When I bought it the interior was disgusting. My Dad and I took out the entire interior except for the door panels, head liner, and dash to clean it.
The best I could get it. At some point, liquid food product becomes carpet dye.
My van at the track
http://youtu.be/-XTqTAdm9-8
My Dad's '85 Chrysler Town & Country wagon that we built. That does 14.7 in the 1/4.
http://youtu.be/mv8Nn05Fa70
A.J.
Old Nov 24, 2011 | 11:16 PM
g. man's Avatar
g. man
WELCOME! I love those video's lol. You got that carpet cleaner than I would have thought too!
Old Nov 25, 2011 | 10:05 AM
Shelbyfan's Avatar
Shelbyfan
nice work. I think I might have some of your older videos of you running the minivan, nope, different colors.
I used to be big into the turbo dodges, CSXT#901, but I had to sell it.
Old Nov 25, 2011 | 12:39 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Nice job! Lets see that Dakota at the track.
Old Nov 25, 2011 | 07:14 PM
AZ 360 Dakota
The smell in the truck was horrible. It would get worse in 115* heat with the windows rolled up. I wouldn't enjoy this truck as much if I had to drive around in someone else's filth.
There's a couple of us mini-van racers out there. You can tell my van from others because it's lifted 2" so I can take it off road to go prairie dog hunting. I'm currently working on a Neon SRT-4 2.4 DOHC engine for my van. The engine is done now I just need to finnish the transmission.
I need to locate and install a limited slip rear axle. This thing is a beast and the tires break loose too easily. I want to know what it does in the 1/4 mile but I don't want to spend the money on drag radials or slicks. It's much more fun beating V-8 trucks with a 4 cylinder mini-van than with a V-8 truck. Now that I have the fuel system worked out to run the 360 on the 318 computer, I can start looking for the rear axle.
A.J.
Old Nov 25, 2011 | 07:32 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It is best to use the 5.9 PCM. I ran my 5.9 with my old 5.2 Mopar Per. PCM, it got to much pinging with high loads and RPM's. Once I put in the 5.9 Mopar Per. PCM it woke it up.
Old Nov 26, 2011 | 10:05 AM
AZ 360 Dakota
I'm trying. There's not too many 5.9's in the junk yard. There are plenty of 318's. Every time I find a van or Ram it's always something other than the 5.9. I had borrowed a friends Mopar Performance PCM for a 5.9 but it pinged real bad. There's a guy over on Turbo-Mopar.com that cracks the code on the chips in the computer so you can tune the factory PCM. I do that on my '88 Caravan. He tried to do it for the 5.2/5.9 SBEC II but he said the code is more complex than the earlier computers. He said he'll get it eventually but it's going to take some time.
A.J.
Old Nov 26, 2011 | 06:43 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Just buy a new Mopar Per. PCM. This is the one you need. http://www.summitracing.com/parts/DCC-5249546/
If you want to tune the PCM I suggest B&G
http://www.bgperformancepcm.com/#magnum
Old Nov 26, 2011 | 07:29 PM
AZ 360 Dakota
Thanks for the links but that's more money than I want to spend. The most expensive thing I bought for my turbo van was the wideband ($260). The SMEC I socketed myself, I had to buy the chip burner (under $100), and the tuning software was free. If i can find a 5.9 computer for $100 then I'll be happy. Don't forget, this is a shop truck and I'm doing it on the cheap. The turbo Dodge/Mopar crowd is known for being cheap and going fast with junkyard parts. Too bad they're drying up in the junkyards.
A.J.
Old Nov 26, 2011 | 07:46 PM
shadowthedakota's Avatar
shadowthedakota
amen to that! atleat from my end...lol
