Problems with engine dying
Old Nov 17, 2013 | 01:11 PM
ohiojack's Avatar
ohiojack
New Member
Default Problems with engine dying
Well i"m still fighting a losing battle with my 1993 Dakota, 5.2 4x4. I replaced my fuel pump and pressure regulator, map sensor and ignition module in the distributor. I'm still having the motor die at crusing speeds and while parking. If I turn the igniton off and coast or allow it to sit for a while it starts right back up. This happens around 2 times a week out of the blue. No check engine light but my mileage has dropped off to around 13 mpg from around 17 when I first got the truck. What do you guys think it is. I'm about ready to get rid of the truck!! Maybe I have to go back to FORD.
Old Nov 18, 2013 | 04:44 PM
paulpa's Avatar
paulpa
where is your filter on a 93,,,,i had the same problem on a 95 and replaced the fuel filter under the cab and things worked fine,,,,,
Old Nov 19, 2013 | 12:49 AM
shadowthedakota's Avatar
shadowthedakota
noooo dont go ford! lol
have you checked the iac?
try taking it out and cleaning it off but dont push it in or out. I sprayed mine with carb cleaner or electrical cleaner then wipe it with a rag. then I spray carb/throttle body cleaner into the hole wipe it clean. it works better if you remove the throttle body.
