96 dodge dakota rough idle
Old Apr 22, 2007 | 08:46 PM
hjw96's Avatar
hjw96
Default 96 dodge dakota rough idle
Ok i have a 1996 Dodge Dakota 2.5L 2 wheel drive and im having some trouble.
when the truck is idleing it will want to die and if i start to go it will start backfireing
and its starting to make me crazy because i dont no whats the reason for it.
At first i thought it was my air filter because there was a crack in one of the
connectors but thats fixed now.whats going on!!! thank you
Old Apr 22, 2007 | 09:29 PM
hjw96's Avatar
hjw96
Default RE: 96 dodge dakota rough idle
ok i was outside and started it up and not it will run for about 1min then start to studder and eventually die. could this be a fuel problem?
Old Apr 22, 2007 | 11:22 PM
codydakota's Avatar
codydakota
almost sounds like timing belt, it did this on my sundance,but my sundance did this when the throttle position sensor went out
Old Apr 23, 2007 | 12:46 AM
JetNoise's Avatar
JetNoise
Is your "Check Engine"light on? If so, what are the codes?
It sounds like it might be an Idle Air Control Valve.
Possibly a front O2 Sensor, but more likely the IAC.
Old Apr 26, 2007 | 12:58 AM
AirForceGuy's Avatar
AirForceGuy
Fuel filter?
