starting problem
Old May 3, 2007 | 07:59 PM
dabeckass's Avatar
dabeckass
Default starting problem
91 3.9L manual
been starting/running sweet
happened twice now
turn key & get nothing no click no cranking nothing
turn key off then on & it fires right up.
alternator putting out........battery o.k. ...... terminals clean
ground ? solenoid ? need input
thanx for your help
Old May 7, 2007 | 01:17 AM
Firstimeround's Avatar
Firstimeround
Default RE: starting problem
Check the switch on the clutch, which has to be pushed in before it will start, make sure it's working and the wires on OK.
