My engine won't idle
Old May 19, 2007 | 11:32 PM
shotzie110's Avatar
shotzie110
Default My engine won't idle
My 92 Dodge Dak. 3.9L 2 WD just quit running. It sat for awhile before I could fix it. But now I have replaced a section of fuel line, fuel filter and coil. I now have it running but only if I keep my foot on the accelerator at a steady RPM the engine runs smooth. When I let drop to idle speed, it dies. HELP!!!
Old May 21, 2007 | 01:39 AM
JetNoise's Avatar
JetNoise
Default RE: My engine won't idle
Have you tried your Idle Air Control Valve?
Old May 21, 2007 | 11:36 AM
shotzie110's Avatar
shotzie110
No...I am new to getting this deep into a repair. Is that like the idle control module?
Old May 24, 2007 | 11:15 AM
shotzie110's Avatar
shotzie110
I put a new battery in and it is running fine. Now when speed approaches 10-15 MPH I get a low pitched vibration the worsens with increased speed. U-Joints?
Old May 24, 2007 | 02:33 PM
fishlessman's Avatar
fishlessman
i would check the ujoints, and maybe the tires first, check for a broken bead or maybe have them balanced.
