95 Catalytic Converter
Old May 23, 2007 | 10:04 PM
mopar fan 157's Avatar
mopar fan 157
Default 95 Catalytic Converter
I am looking to replace the Catalytic Converter (95, 3.9, Auto, Short Bed 112" Wheel Base, Standard Cab, 4wd, Sport). The one it took off has a tag riveted on that says (440W5033). It is 60" long overall.It measures4.5" from the end of the Converter body to the end of the pipe on the Muffler Side. I have tried Advance Auto Parts and Napa without luck. The O.E. direct fit parts are either too long overall or the converter is located in the center of the pipe and 4.5 from the end on the muffler side.
Any help you could give, would be appreciated.
Thanks,
Mopar Fan 157
Old May 24, 2007 | 09:22 AM
BAnders's Avatar
BAnders
Default RE: 95 Catalytic Converter
jcwhitney.com
Old Jul 10, 2007 | 08:38 PM
kent_08's Avatar
kent_08
did you find a catalytic converter for your ride? anyways, you may also search ebay or some parts stores.. or perhaps, check junk yards... there are tons of dodge catalytic converter that are available, I'm sure you'll able to find one.. good luck
Old Jul 13, 2007 | 10:15 AM
Bad96_3.9's Avatar
Bad96_3.9
You could save alot of money by not putting one back on there, 95 is pre-obd2, unless your state checks emissions, that would suck.
Old Jul 16, 2007 | 09:58 PM
Firstimeround's Avatar
Firstimeround
If your still looking, try rockauto.com
Old Jul 18, 2007 | 12:31 AM
dodgerules86's Avatar
dodgerules86
ORIGINAL: Bad96_3.9
You could save alot of money by not putting one back on there...
+1
Old Jul 20, 2007 | 05:26 AM
minie's Avatar
minie
If you are still looking....I am thinking of magnaflow.
