89' V6 Noise follows RPM - harsh rattle
Old May 24, 2007 | 07:18 PM
justindubois's Avatar
justindubois
Default 89' V6 Noise follows RPM - harsh rattle
On sudden throttle input, or above 2000rpm, my 89 V6 Dakota has a rattling noise coming from the engine. The Belts and Fan do not appear to be rubbing anything, so I'm wondering if this is what a loose timing chain sounds like?
The engine has 244,000 mi on it.
Suggestions?
How hard is it to replace a timing chain/gear set?
Justin
Old May 26, 2007 | 08:06 PM
wink2873's Avatar
wink2873
Default RE: 89' V6 Noise follows RPM - harsh rattle
could be a rod knocking or a bad lifter.
Old May 26, 2007 | 09:26 PM
justindubois
I just found a way to measure the chain slop without dis-assembling the engine. I think I'll start there first.
Old May 28, 2007 | 06:57 PM
JaYmZ's Avatar
JaYmZ
yah that would be a good place to start a lose chane or the timeing just being off can make a clater if thats not the truble check your cadilitic converter they have a sheald that can rust and make a rattle at sertin rpm's
