problem could be. brake and turn light problem on 95 dak
Old May 30, 2007 | 09:37 PM
blukota's Avatar
blukota
Default problem could be. brake and turn light problem on 95 dak
the brake light and the turn signal doesnt work on the left rear. but the driving light works, and all the wires seem fine and i changed the bulb like 4 times. what do you think the problem could be. also all the other lights work fine, its just the brake and turn on that one side. i changed the fuse and that did nothing as well.
Old May 31, 2007 | 02:30 AM
JaYmZ's Avatar
JaYmZ
Default RE: problem could be. brake and turn light problem on 95 dak
hey whats up im having the same truble i was toled it was a switch on the brake. now i know its right above the steering collumtrace the brake pedle it ez to find,but ill be damned if i can figuer out how to remove it
Old May 31, 2007 | 02:43 AM
blukota's Avatar
blukota
ill look for that. thanks man
