Brake,hazard and turn signal fuses blowing
Old Jul 8, 2007 | 01:04 PM
eaglesnest's Avatar
eaglesnest
Default Brake,hazard and turn signal fuses blowing
Hi All,
I am new to this forum so please bare with me. I have a 93 dodge dakota that has just statred blowing the brake , turn signal fuses under the dash and the hazard 20 amp fuse under the hood either when the turn signals are truned on or the brake pedal is pressed. It started with my ABS/Brake lights on the dash came on and after a little while just blinked. I do have a trailer brake installed that I have not use for quite a while so I disconnected that wireing from the back to eliminate that as a possible problem but still happens. what get me is all 3 fuses blow at the same time. Can anyone help?
Thanks
