1992 w150 5.2 sensor
Old Sep 2, 2007 | 10:29 PM
Gordoc4's Avatar
Gordoc4
Default 1992 w150 5.2 sensor
Does anyone know if the 92 318 has another spot where I can install a water temp sensor, the factory water temp sensor is too small.
thanks
Old Sep 2, 2007 | 11:55 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: 1992 w150 5.2 sensor
ya anywhere next to the coolant sensor and the thermostat Take off the thermostat and look inside. easyer if there is no fuid inside. you will see the coolent passage way travels along the front. just choose a spot drill and tap and install.
