1988 Dakota 4x4
Old Oct 30, 2004 | 10:47 PM
LemmeBeeMee's Avatar
LemmeBeeMee
Default 1988 Dakota 4x4
I Just bought my Semi Annual winter beater... a 1988 Dodge Dakota 4x4 long bed.. 3.9 L V-6
Brake light's stuck on.. and the "Hydraulic system control valve" is leaking fluid.. Any Pointers?
Other than that it was a GREAT buy at $1000.. since the book's $1995, and it's got $1000 worth of tires.... It's kinda like a free truck
Has a few flukey little electrical things... but I'll figure 'em out.
Old Oct 31, 2004 | 11:19 PM
LemmeBeeMee
Default RE: 1988 Dakota 4x4
Upon firther review (In the day light with a little assistance... ) The leak is a brake line, and not the valve.... Anyone got any pointers for a temorary splice to hold me over till the brake line I ordered comes in? I'm thinking of cutting out the damaged portion and splicing it with some brake hose... (2 weeks to get the new part)
Somebody scream at me if It's going to kill me or anything.
Old Nov 4, 2004 | 02:37 AM
injmopar's Avatar
injmopar
brake line pressure is around 1000 psi . If you have a flaring tool, you can buy short pieces of steel brakeline and fittings at most autoparts stores.
Old Nov 13, 2004 | 11:22 PM
TR|T0N's Avatar
TR|T0N
i have also had very good luck with brass compression fittings on brake lines
Old Dec 2, 2004 | 04:57 AM
LemmeBeeMee
I just tossed in the towel and replaced ALL of the Stainless brake lines... MANY of 'em were a BEAR to get out....
Two New Rotors.. one rear drum... $300 and it goes like a bat outta hell.. and STOPS, too.
Since then.. I've had to fix a lotta small naggy little things... (worst of which was a leaky gas line under the truck.... (Dead ends offa the TOP of the tank))
Took the connector out of the blower motor resistor, and soldered the wires on... now THAT owrks.
Replaced the right front Turn Signal socket ($4.99 at Murrays')
Got the locking lugs (no key) off with a 19 MM Crafsman Socket and a BFH.
Still no backup lights... Probable tranny switch..
Even got hold of a Cassette Radio (Stock) and threw it in...
I've got it down, now where all that's left is findng the hole in the "mant Req'd Module", So I can Reset it.
All in all not too bad for a $1000 4x4..
