Tightening Belt
Old Sep 18, 2007 | 11:42 AM
DeanEH's Avatar
DeanEH
Default Tightening Belt
Is there a way to tighten the serpentine belt of a 1994 Dodge Dakota? I am replacing the old belt but the new belt seems to be not as tight.[sm=feedback.gif]
Old Sep 18, 2007 | 12:28 PM
pashadowops's Avatar
pashadowops
Default RE: Tightening Belt
I don't see an adjustment for the tensioner on my '95. You may have to replace the tensioner pulley. You might want to verify that they gave you the right belt. It took the guys at my local store 3 tries to get it right. My belt broke on the highway so I didn't have it to match up.
Old Sep 18, 2007 | 12:36 PM
DeanEH's Avatar
DeanEH
Thanks for the reply. I didn't see away of tightening the belt either. I thought I might have missed something. I put the old belt back on because my Check Engine light came on when I installed the new belt. When I put my old belt back on the Check Engine light stopped coming on. My local Dodge dealer didn't have a belt in stock so I had to get one at NAPA.
Old Sep 18, 2007 | 01:37 PM
DeanEH's Avatar
DeanEH
I found the answer to my own problem. I had installed the serpentine belt incorrectly. I am the original owner and this only the second time I have replaced this belt. Everything works fine now.
Old Sep 18, 2007 | 01:47 PM
Wick93's Avatar
Wick93
And I was about to tell you that you may have put it on wrong or maybe they gave you the wrong one. Also, the tensioner could be going bad. Glad you fixed it.
