93 dakota 5.2L dies while driving
my 93 dies while driving very intermittingly, replace pick-up coil,cap and rotor. the next day it died again so i checked for spark at coil and had none so i replaced the coil, still dies very intermittingly while driving, check for codes using the ignition key method(three times on/off) code 55/no faults. will start up after setting for about 5min. anybody have any ideas for me to check.
Think i solved my problem,found the answer on anthor post. Pos wire connection/splice to fuse/relay box corroded, not fully pluged together, powers the whole fuse/relay box on left fender. keeping my fingers crossed anyway.
