'95 Sport
Old Nov 7, 2004 | 08:42 PM
95sport's Avatar
95sport
Default '95 Sport
Hi guys, new here and got a question. The AC/Heater fan quit the other morning. Over the last couple of years I have hade an intermittent ticking noise as if something was hitting the fan blades. It came and went and other than being annoying it didn't affect performance. I also had some trouble with the switch that it would turn the fan off when I put it on high. Several months ago that stopped and the fan has worked normally except for the occasional ticking. Now the fan has quit all together, several times while operating the switch since it quit I've heard that ticking noise for less than one second, it would tick very quietly 3 or 4 times and then nothing. I've read something about a resistor that may be a problem. Does anyone have any advice.
Thanks,
Travis
Old Nov 9, 2004 | 01:02 PM
Sneezer's Avatar
Sneezer
Default RE: '95 Sport
You may have a blown resistor pack. Fairly common on these trucks. Located in the engine bay, passenger side, on the firewall. Two screws hold it in, and has a cable connected to it. About 5 spade connectors on it I think. If you pull it out and it is corroded you will need a new one. About $15-20 at the dealer.
Old Nov 9, 2004 | 03:06 PM
Little Black Dak's Avatar
Little Black Dak
Don't forget to check out the blower switch as well ... I have a '94 that had the same problem (would work and then not), turns out I just wore out my switch.
Old Nov 9, 2004 | 05:22 PM
GMsucks's Avatar
GMsucks
If the blower motor resistor was bad you would still have the "High" position.
Turn the fan on "High" and check for 12.6 volts across the fan leads. If ya got 12.6v or higher (within reason), the blower motor is bad.
Old Nov 29, 2011 | 11:19 AM
ngtyler1s's Avatar
ngtyler1s
My 1995 Dakotas blower did the same stuff. The switch turned out to be partially melted and replacing it fixed it.
Old Nov 29, 2011 | 11:46 AM
marcar1993's Avatar
marcar1993
Not to steal his thread, but if it doesn't work on high, but does on all the other settings, whats the cause?
Old Nov 29, 2011 | 01:41 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The blower motor resister. There is a picture in the FAQ.
