swap questions
Old Nov 17, 2011 | 10:46 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by MAGNUM-JENNINGS
I have a 93 4x4 5sp 3.9l .I'm looking at a 5.2 from a 92 ram.I know the oil pan and pickup tube will not work.Will the intake/fuel rail/throttle body/exhaust manifolds fit without modification?
Yes it all will. The only thing I think and not know is the exhaust manifold to the pipes, I think it will be a direct bolt on.
Also don't be scared to start a new thread instead of posting a very old one.
Old Feb 11, 2012 | 07:32 PM
kemajic's Avatar
kemajic
Default Gen I 4WD V8 Swap
I have a sweetheart '87 Dak 3.9 4WD short box standard cab manual, AC, loaded, that I bought new. It now has about 115 M miles and is completely original. Never a problem, except of course, it can't get out of its own way. It's even worse because it came with the 2.9 gears and 5th is only good for downhill with a tail wind. Pretty soft suspension as well. I want to repower it; it appears a stroker is not an option, so a 318/360 is my next consideration. I have a low miles 360 from a '77 1 ton PowerWagon if I could get it in there. I hear the 5 spd is unlikely to hold up - I'm not a racer, just need some low end guts. Is there existing documentation of this swap or available commercial swap kits? I'm an old guy, so project wise, smaller is better; decent knucklebuster, but welding will have to be out-sourced. Any help appreciated.
