Weird Headlight Problem
Old Oct 26, 2007 | 04:30 PM
projectdakota22's Avatar
projectdakota22
Default Weird Headlight Problem
Hey, I am stumped on a problem with my headlights on my 96 dakota 3.9. I did a brake job to the back brakes (nothing out of the ordinary), go for a test drive and notice my headlights will not turn off, so after pulling the dash apart to get at the light **** (headlight switch), I just decided to run a switch on the main power for the headlights (going to the switch) before it hits the switch, and surprising everything worked. I tried it out and it worked good, but after about half an hour i tested it again and i had no power to my switch, at this point I was beyond confused so I came instead to research. Any help would be greaty appreciated!
Old Oct 26, 2007 | 06:47 PM
codydakota's Avatar
codydakota
Default RE: Weird Headlight Problem
faulty switch, poor continuity in the wiring or broken wiring, bad connection
Old Oct 26, 2007 | 08:20 PM
projectdakota22
ok, just went out and found out that I have no power going to my main lightswitch (for headlights, interior dimmer, gauge lights, etc..). Does anybody have a schematic of the headlight electrical system? are there any fuses that may have went that I could check? my manual doesn't tell me much...
Old Oct 26, 2007 | 08:54 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Check out the FAQ in this section. (1st gen. Dakota) There is wireing diagrams and check all fuses.
Old Oct 27, 2007 | 01:20 AM
flyers win the cup's Avatar
flyers win the cup
i have a 105 page wiring diagram for 87 - 96 daks. but i don't know how to upload the file. it has every possible wiring diagram for gen 1 daks, both throttlebody and multiport. all that i can tell you it's a pdf file. any help uploading this file would be apperciated, im kinda new to uploading files.
Old Oct 27, 2007 | 09:49 AM
projectdakota22
K, well I found a blow fuse, and now the problem is the daytime running lights do not shut off when i turn off the truck. Does anybody know whcih wire this is that connects to my main headlight switch? or where I could find the fuse to this daytime running light circuit?
Old Oct 27, 2007 | 01:21 PM
davester's Avatar
davester
near the firewall on passenger side u can unplugg the circit for the daytime lights. Tape up the holes after. (sugestion)
Old Oct 27, 2007 | 05:20 PM
projectdakota22
I like that thinking, know where exactly is the wireI unplug?
Old Oct 27, 2007 | 05:51 PM
projectdakota22
Nevermind, found it. Thanks for all the input!
Old Oct 29, 2007 | 10:53 AM
peacockj's Avatar
peacockj
flyers win the cup: You can try uploading the files here: http://www.scribd.com/upload
Someone posted a transmission .pdf manual there successfully before. I'm sure a lot of people would appreciate your effor![sm=goodidea.gif]
