vibration
Old Nov 17, 2007 | 04:04 PM
hbowolfe's Avatar
hbowolfe
Default vibration
i have an 87 2wd dakota, i get this vibration at around 40 to 45, it feels like it is in the front end . sometimes more severe than others. i have put the truck in nuetral when this happens and it is still there. i have tightened the wheel bearings, ujoints seem fine, a little play in the inner tie rod but not alot. carrier bearing is new. anyone have any ideas, thanks.
Old Nov 17, 2007 | 04:13 PM
kahanabob's Avatar
kahanabob
Default RE: vibration
Check the two big bolts that attach the rack to the frame. They have been known to tear away from the frame.
Old Nov 17, 2007 | 05:28 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You should also check all your bushings for the control arms too.
