carb. magnum...
Old Nov 21, 2007 | 11:26 PM
Bad96_3.9's Avatar
Bad96_3.9
Default carb. magnum...
Has anyone ever done a carb swap ona 318 magnum? I am getting a long block 318 and dont have the money to buy all of the fuel injection stuff for it. Summit has and edelbrock air gap for 295 and i have a 600 performer already, the only thing i have been wondering about is the ignition, what distributor can i use, will one out of and older la 318 work? I have one of those already, so if it works that would be good. and my transmission... i have a 42re in it now behind the 3.9, but it needs the computer to shift dont it? if it will shift without the comp. i will use it till i can get a 46rh for it. i have a 727 too, but with gas how it is now i am not ready for a 3 speed in it. i am going to go to the junkyard later on this week to see if they have any more dakotas out there, i would really like a 5 speed in it, all i would need would be the tranny, flywheel, clutch assembly, brake/clutch pedal assembly, and the master cylinder right? plus if i get a 5 speed i can throw a bigger cam in it and not need a stall converter[8D].
Old Nov 22, 2007 | 12:46 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: carb. magnum...
The Edelbrock intakes are designed for LA blocks and won't work on the magnums. Very different heads.
Old Nov 22, 2007 | 05:09 PM
Bad96_3.9's Avatar
Bad96_3.9
it is the edelbrock intake for the magnum....... which is more expensive than the $195 for the LA!
Old Nov 22, 2007 | 05:33 PM
Bad96_3.9's Avatar
Bad96_3.9
http://store.summitracing.com/partde...p;autoview=sku there is the link to the MAGNUM intake, ths bolts go straight down into the heads.....
Old Nov 22, 2007 | 06:14 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Moparperformance.com sells the carb intakes for mag. engines too.
Old Nov 23, 2007 | 10:29 AM
hemichuck's Avatar
hemichuck
There is an intake from proffesional products which is called a crosswind and it looks just like the performer RPM airgap except for the thermostat location(AC interference)but it fits both the LA and Magnum heads and they are all over e-bay for $150. I've had several of them.
