96 Dakota dies
Old Nov 26, 2007 | 08:45 PM
joeahi's Avatar
joeahi
Default 96 Dakota dies
Have a 96 Dakota and having a problem thats getting to me. This truck ,I can drive a few miles aqnd it just shuts down and will not start. Can let it sit awhile and it'll start up fine and go for a few miles. It's almost like when everythings gets at operating temp. that this happens. I thought it was fuel pump and changed it but does the same thing. Help!!
This is a 4 cyl. with only 76000 miles on it.
Old Nov 26, 2007 | 09:47 PM
iraqvet's Avatar
iraqvet
Default RE: 96 Dakota dies
I'd guess a bad crankshaft position sensor
Old Nov 28, 2007 | 10:55 AM
partsman31523's Avatar
partsman31523
this happened to my moms buick lesabre too! we KNEW it was the cps but after changing it she continued to have the same problem. There were two on her GM 3.8L. Replaced the rear one and WOOOOOOOOHOOOOOOOOOO!! Never staslled again! From asking around, the bad CPS causes the same problem no matter the vehicle or manufacturer! Hope this helps!
Old Dec 8, 2007 | 08:43 PM
lesimon's Avatar
lesimon
Id say possibly HEP Relay (pick-up coil)under the distributor
Old Dec 9, 2007 | 12:55 AM
Bad96_3.9's Avatar
Bad96_3.9
it probably is the cps sensor likeiraqvetand partsman31523said, i worked at a shop for a while and there was a 96 318 dakota doing the same thing, that is what fixed his, it was a bish to change though!!!
