WARNING: JET modules
Old Dec 8, 2007 | 05:08 PM
95V8Dakota4x4's Avatar
95V8Dakota4x4
Default WARNING: JET modules
So it turns out that the fuel pump was not my problem. Nor was it anything to do with the distributor. The JET Stage 2 module I had installed over a year ago suddenly failed. And it's taken my computer with it. I've contacted JET's customer service, and asked them to refund me for the module and replace my ECM as well.
It took two contact pins and the entire nut and bolt assembly with it. I installed it correctly with no issues, and it ran fine until this Monday, so I have a hunch that the failure caused enough heat to fatigue the plastic directly around the plug area. The bolt wouldn't unthread (it turned but wouldn't come out) and when I tried working it gently by hand it suddenly pulled right out.
It smells pretty rank too...
Old Dec 8, 2007 | 05:53 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: WARNING: JET modules
Exact same problems I had when I got mine. They are POS. It took out my pins for the injectors. At the time I sodered in wires at the pin locations and the computer worked fine. Now I have the mopar per. comp. so no more bad wire pins. The bolt nut broke out of the computer too. It would be nice if the do refund you. But Im sorry to say I belive your SOL.
Old Dec 8, 2007 | 09:27 PM
wink2873's Avatar
wink2873
wow...i would say take it to a dealer and have them fix whatever needs to be done and maybe try to get it in writing from a mechanic or something that the jet chip caused the failure and then send them the bill. if that doesnt work, threaten a lawsuit if it ends up costing you alot of money.
Old Dec 9, 2007 | 12:48 AM
Bad96_3.9's Avatar
Bad96_3.9
what year is your truck, cuz my jet module looks way different than that one...
Old Dec 9, 2007 | 04:48 PM
95V8Dakota4x4
ORIGINAL: Bad96_3.9
My username might give a hint......
Old Dec 9, 2007 | 05:44 PM
dodgerules86's Avatar
dodgerules86
ORIGINAL: Bad96_3.9
I can't see the pictures (damn Air Force blocking sites like photobucket); but 1995 and previous Dakota's used a single (60?) pin connector, where-as 1996+ Dakotas use 3-(32?) pin connectors.
Old Dec 9, 2007 | 06:08 PM
95V8Dakota4x4
Does that mean that Dakotas were OBD2 starting in '96?
Old Dec 9, 2007 | 06:35 PM
dodgerules86
Yes.
Old Dec 9, 2007 | 08:06 PM
Bad96_3.9's Avatar
Bad96_3.9
lol, my bad. Dont know how many times i have looked at that thing 95V8Dakota4x4. But all cars started obd2 in 96, i did not know that the wiring harness had canged in between the years like that.
Old Dec 10, 2007 | 09:28 PM
95V8Dakota4x4
Still no answer...they'd better not try and brush me off. Considering it looks like this thing damn near caught fire, I'm sure I could make somewhat of a ****fest for them. That's not just a failure, that's a safety issue.
