stalling issues
Old Jan 20, 2008 | 03:14 PM
dale2themax's Avatar
dale2themax
Default stalling issues
i have 92 dakota 3.9l , the problem im having is that the truck stalls out while driving some times after is first stated. while driving when it stalls i have to pull over come to a complete stop wait a few minutes and then it will fire up.i have replaced to fuel pump,distributor,cap&rotor,plugs,wires,crank sensor,pick coil,tried an ecm and after all that still the same thing. if anyone have any ideas it will be helpfull. thanks
Old Jan 20, 2008 | 07:16 PM
kahanabob's Avatar
kahanabob
Default RE: stalling issues
Do you have a in-line fuel filter? My 90 has one on the drivers side on the frame. I guess they stoped useing them in later years don't know about 92. If you have one replace it sounds like the problem, maybe?
Old Jan 20, 2008 | 08:28 PM
dale2themax
yeah it does have an inline filter, but i replaced it when i got the truck, only driven the truck for aprox 3,100 miles. thanks
Old Jan 20, 2008 | 11:19 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Maybe a relay, bad wireing, Bad IAC, Vacuum leak,when it dies is at idle? or any rpms? does it just die? or struggle then die? Give more info
Old Jan 21, 2008 | 07:36 PM
dale2themax
it dies at idle, but mostly when im driving at just below 2000 rpm. i have checked the relays, looked for vacuum leaks with carb cleaner, the iac has checked out ok. the bulkhead connector on the firewall had a bad terminal and was replaced, but still the same. the engine runs strong no hesitating it just shuts down. I tried the tps and map sensors but that did nothing.I forgot to mention that i replaced the O2 sensor, catalytic converter and the rest of the exhaust. the codes i get are 12 and 55.
