looking for a sumwhat inexpensive lift kit for a 1995 dakota 3.9 mag 4x4 im not a fan of body lifts and blocks in the back only do so much i need somethin for the front
i dont know if the 95 has torsion bars up front, but if it does you can gain a couple inches just by cranking those up and adding some spring over shocks. rides much firmer and things may wear out a little quicker but its the cheapest way. i run spring overs in the front and airs in the back, some dont like air shocks so thats up to you, but its the cheapest and easiest way to go without the sway you can get from blocks. i bought the shocks here for less than a hundred per pair, custom made a couple years ago. https://www.shockshopusa.com/thankyou.html
