cant find drl module
Old Feb 21, 2008 | 07:03 PM
davester's Avatar
davester
Default cant find drl module
I looked in the faq and still cant find the drl. does anyone know how it looks like, or maybe a picture would be really cool. Thanks.
Old Feb 21, 2008 | 10:04 PM
dodgerules86's Avatar
dodgerules86
Default RE: cant find drl module
Depending on year, its either on the left sie of the engine compartment (i.e. drivers side appx. in the middle) or right side of the engine compartment (i.e. passenger side, just to the rear of the PCM).
It's typically secured with one (1) screw/bolt, and has a ten pin connector (3 of the pins aren't used).
Old Feb 23, 2008 | 07:41 PM
davester's Avatar
davester
thanks for your help. Its a 91 5.2 and I found it on the drivers side of the engine. This is a truck that was played around alot with, (I mean like the wiring and stuff) so I found this square 12v relay or something with four wires connected in. That was it!
