PLEASE HELP
Old Feb 24, 2008 | 05:52 PM
valuetech's Avatar
valuetech
Default PLEASE HELP
Hello. I have a 1989 Dodge Dakota 4x4 6cyl. My truck will run for a while and then just shut down. No spuddering, spitting, ect... This may happen every day for a week and then not happen for months. It does not matter what I'm doing at the time. I can be at idle or going down the road. I have replaced the following parts: ign switch, distributor, plugs & wires, hall effects, cap, rotor, and coil. Thanks for your Help!!!
Old Feb 24, 2008 | 09:57 PM
95gotmagnum?'s Avatar
95gotmagnum?
Default RE: PLEASE HELP
could be many different things, as you probably already know
because i see you have replaced alot of diff. things
Since your already on the electrical path i would look at the computer!
Or maybe its not electrical at all it may be fuel related
Does it start back right away after it has one of these fits?
Old Feb 25, 2008 | 04:16 AM
valuetech's Avatar
valuetech
Thanks for your post magnum. It never starts right back up. However, it will always start after it sits a while. The time varies anywhere from 10 minutes to hours. Thanks!
Old Feb 27, 2008 | 07:02 PM
95gotmagnum?
Sounds like something is gettin hot maybe! but still I would guess fuel Let me know how it goes
Old Feb 29, 2008 | 10:14 PM
alterboy's Avatar
alterboy
Sounds like the auto shut down relay. If this relay is worn out the metal bands can move due to heat but when they cool they can move just far enough so the truck will restart. This may be then next cheapest part you can try for troubleshooting. There is a pic of the locationat the web site I posted below. I didn't check out the website But it looks like it could be very helpful. Good luck
http://autorepair.about.com/library/...bl659a-lib.htm
Old Aug 17, 2008 | 07:41 PM
valuetech's Avatar
valuetech
Talking Problem solved
Thanks to everyone for the suggestions. The truck finally completely quit running. I checked everything I knew how. After reading & testing I came to the conclusion that it must be the ASD relay, computer, or camshaft position sensor (Hall Effect). I had put a new CS position sensor in last year that I bought from Advance. I decided to put the old one in and if fired right up. Thanks Again!
Old Oct 18, 2008 | 10:52 AM
valuetech's Avatar
valuetech
Smile Problem Solved--I think
This topic can be closed
