oil
Old Apr 7, 2008 | 02:46 PM
TheePlaymaker's Avatar
TheePlaymaker
Default RE: oil
stewtina what made you make that decision just curious was it really that much of a difference.
Old Apr 9, 2008 | 09:42 AM
DukeSupes's Avatar
DukeSupes
Default RE: oil
This is all very interesting to me as I have had my 93 5.2 for a little over a year now and I was running 10W-30 as recommended and the truck just didnt get enough oil pressure (Running rough and dummy oil light coming on). So I switched to 10w-40 and that helped. As an added peace of mind I have been using the STP additive with my oil change.
So to make sure I understand this, Synthetic is technically lighter than conventional oil. Thus throwing me back into the problem with oil pressure. But I sure would like to be getting the bestter gas mileage if that truly is the case with sythentic.
Old Apr 9, 2008 | 10:48 AM
OneBadKota's Avatar
OneBadKota
Default RE: oil
ORIGINAL: DukeSupes
It keeps the engine cleaner and no sludge crap buildup so the engine can run better. It would help some with gas mileage, but not real big improvement.
Old Apr 9, 2008 | 12:33 PM
dolfans's Avatar
dolfans
Default RE: oil
what kind of filter can be used?i use mopar filter will it work with synthetic oil
Old Apr 9, 2008 | 01:47 PM
OneBadKota's Avatar
OneBadKota
Default RE: oil
ORIGINAL: dolfans
You can, I usea regular one, but I change after 3,000 miles. Soon I'll just be going 4k-5k and will be updating to a filter that is made for the longer mileage. I'm afraid to take any chances otherwise.
Old Apr 9, 2008 | 01:48 PM
OneBadKota's Avatar
OneBadKota
Default RE: oil
ORIGINAL: dolfans
Old Apr 11, 2008 | 05:37 PM
sprocket1200's Avatar
sprocket1200
Default RE: oil
go to mobil1.com
you can change oil every 6-8K miles easy, same with filter.
i do 6500 miles with the 2001 grand cherokee and 8000 miles with the 98 BMW 323. 100,000 miles on both of them, no issues.
Old Apr 11, 2008 | 10:15 PM
Bad96_3.9's Avatar
Bad96_3.9
Default RE: oil
try the k&n filters or the mobil filters. i am going to start running the k&n after the 318 is broke in, they are easier to change because there is a nut on the bottom of them too.
