94-96 wiring/electrical info needed
Old Apr 10, 2008 | 07:13 PM
dakota_widower's Avatar
dakota_widower
Default 94-96 wiring/electrical info needed
Greetings,
I need the wire descriptions (circuit, gauge, color and function) for the two plugs on the back of the instrument cluster (gray and red.) There should be a dedicated page in the factory service manual. Its from a 95 but i believe 94-96 are the same.
Also, what is the resistance range for the fuel gauge?
Thanks
Old Apr 10, 2008 | 07:27 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: 94 wiring/electrical info needed
There are some wiring digrams on the faq in this section, I belive its a 90 but most likly close to urs. also try autozone.com they have a full set of wire diagrams for all years
Old Apr 11, 2008 | 02:46 AM
dakota_widower
Thanks but been there, done that. I dug through the faq and searched for a while. The 90 doesn't match (or even come close) to the 94. I would hardly call AZ wiring diagrams "full". While they're better than a haynes/chiltons, I'm spoiled from using factory manuals
Old Apr 11, 2008 | 02:59 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya I know what you meen. But thats all that is out there forfree.I bought mine from dodge for $70. Go to alldata.com buy everything you need for $25.
Old Apr 14, 2008 | 03:32 AM
dakota_widower
Got most of it figured out. Found a 96 wiring diagram on a russian web site.
I still don't know what the light blue/black wire is. If someone could ID it that would be outstanding.
Old Apr 14, 2008 | 03:41 PM
Crazy4x4RT's Avatar
Crazy4x4RT
low fuel lamp
If you have the site you found for the russin diagrams please post so others could use too.
[IMG]local://upfiles/70180/DF5D518302FF4CBEBD42CBAFDC445827.gif[/IMG]
Old Apr 14, 2008 | 06:51 PM
dakota_widower
http://www.mitchell-auto.ru/UserFile...-dakota-wd.pdf
