94 Dakota battery is sparking
Old Apr 17, 2008 | 12:51 PM
rajah86's Avatar
rajah86
Default 94 Dakota battery is sparking
Hi,
My 94 3.9L Dakota wouldn't start this morning. I turned it over and nothing, no click. The dome light came on when I opened the door. I checked the connections on the battery and found a little buildup so I took them off and cleaned the cables and the terminals. I re-attached the terminals and had my daughter try to start the truck. It did try to start. While trying to start I saw a spark come from the cable/terminal connection on the battery (the terminal closest to the grille). After that the truck would not start again (again no click). Has anyone else had this problem and how did you fix it?
Thank you in advance for your assistance. This forum has helped me alot with my truck in the past.
Old Apr 17, 2008 | 01:18 PM
Airmanbeard's Avatar
Airmanbeard
Default RE: 94 Dakota battery is sparking
try pulling the coil wire and just holding it real close to the plug on the distributer while turning it over.
Old Apr 17, 2008 | 01:21 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
If ya get shocked though its gonna hurt like a *****
Old Apr 17, 2008 | 01:23 PM
Airmanbeard
thats why you grab the rubber part sillly. but yeah keep your hands and feet clear at all times cause it would hurt like a mother lol
Old Apr 17, 2008 | 02:14 PM
kahanabob's Avatar
kahanabob
Clean the battery posts and connectors again best to use wire wheel on a drill.
Old Apr 17, 2008 | 06:30 PM
jlbritt1's Avatar
jlbritt1
Replace the terminal ends. I just went through the same exact thing with my '94 3.9. The terminal that's sparking is the negative terminal. I replaced both ends (they came as a set at Wal-Mart for 5 bucks with the little discs that supposedly stop corrosion, and the ends are painted red and black) have had no problem since.
