Motor Mount question
Old Apr 17, 2008 | 10:56 PM
ispeedfrk8537's Avatar
ispeedfrk8537
Default Motor Mount question
I have a 92 Dakota 3.9 Magnum V6 is there any way to change the motor mounts with the engine still in the truck
Old Apr 17, 2008 | 11:08 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Default RE: Motor Mount question
Yeh its possible. You just have to be careful you dont smash you hands [8D]or the oil pan. I used a jack and a couble blocks of wood to push/hold the engine up. Its def tight spot to work, but it can be done.
Old Apr 17, 2008 | 11:49 PM
OneBadKota's Avatar
OneBadKota
Yes, just get a cherry picker and have it hold the motor. It should lift up a fair amount (everything attached) and you should be able to swap them.
Old Apr 18, 2008 | 11:19 PM
Bad96_3.9's Avatar
Bad96_3.9
x2 with these guys. it is aa pita to do, i still have not put the transmission braces back on my truck
