questions
Old Apr 20, 2008 | 09:02 PM
dakotacrash17's Avatar
dakotacrash17
Default questions
ive decided to keep my v6 and do some mods to it. i was wondering if anybody knew where i could get some headers and/or any other add ons for the 3.9 v6.
Old Apr 20, 2008 | 10:44 PM
dive_bomb's Avatar
dive_bomb
Default RE: questions
yeah... about that
there really are none. from what i hear, the things that actually are available, such as jet chip and throttle body spacer, do nothing. you probably aren't going to get any big performance out of that engine. if you just want a little more horsepower i recommend a less restrictive exhaust system, k&n air filter, and 180 degree thermostat. if you have deep pockets, try this site: http://socaldakota.com/
Old Apr 21, 2008 | 12:02 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya I heard no headers. But Im sure you could get a v6 headers from a ram or something and try to make it fit. There should be enough room there. You can get larger tb Higher cam larger pistons higher flow injectors. better plugs higher coil wirescaprotor.lots of things. Most stuff may not be spacific but remember rams durangos newer dakotas have the same engine. Check out sumitracing.com jegs.com moparperformance.com jcw.com ebay.com here is good site with performace hints http://www.v8performance.com/tipsandtricks.htm
