better mpg and horsepower......
Old Jun 18, 2008 | 04:20 PM
xxxxrhodesxxxx's Avatar
xxxxrhodesxxxx
Default better mpg and horsepower......
i have a friend that will sell all of this wat should i get from him heres wat he has.......complete engine 1996. It has a thrown rod so the bottom end is shot but the heads and intake and camare still good. I believe it has the roller cam assembly which should be used in the conversion. Before the rod let go it was running well according to the previous owner.
It has the throttle body and injectors. I also have a wiring harness from a 99 along with the distributor and sensors. Should be almost everything needed to convert one over to a magnum... let it all go for the $150
[/align]
wat should i get from him and plus is that a good deal...!!!!!!
Old Jun 19, 2008 | 08:03 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: better mpg and horsepower......
If thats what your looking for, then go for it. Get everything you can. The best thing would acculy buy the truck off of him. Just incase you forget a small pice or where something goes. But you should get all wires,computer, tranny and motor mounts, driveshaft.
