Air Conditioner on 93 Dakota V8
Old Jul 2, 2008 | 02:05 AM
jordanhoff's Avatar
jordanhoff
Default Air Conditioner on 93 Dakota V8
I replaced the condenser on my truck today and we started to recharge the A/C unit and the compressor will not turn on, i hooked it up straight to the battery and it worked and we then finished filling up the system and i still cannot get it to turn on. The connector has 12-13 volts but then on the compressor side of the connector it only has .12 volts once it is hooked up. Also what fuse does the A/C run off because i believe i just blew it. does anyone have any idea what is wrong? please help.
thanks in advance
jordanhoff
Old Jul 2, 2008 | 09:31 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: Air Conditioner on 93 Dakota V8
Doesnt the fuse block tell you what fuses are what ? Very bad idea jumping and filling the compressor that way. And when you did connect it to the battery directly did you remove the plug first?
Old Jul 2, 2008 | 11:22 AM
codydakota's Avatar
codydakota
Check the relay, swap it with a known good one (like the starter relay) if the truck won't start, it's a bad relay causing the a/c not to turn on. If the truck does start, turn it off and try again and again just to make sure it's not an intermittent thing. I just went thru this with my '92
