Which fan to choose...
ok im doing the electric fan swap What I want to do is just run a manual switch. I got one out a 93 mecurry sable for FREE but still need to get a wiring and mounting kit, but I here all the roar about the mark Viii fan and theres one ebay out a 96 t-birdwith wiringfor about 60$. So which one should I go with? wanted ur guys opionions on this.
i bought a mark 8 fan and it wont fit!!![:@]it is an awesome fan too, even with trimming there was no wat. get the thinnest one you can , the sabel one will probably work. i just hooked mine up toa toggle in the cab too. you will want to use a relay though from the curent the fan draws.
ORIGINAL: codydakota
Actually the one out of the intrepid is an almost perfect fit and would probably be your best bet
Im gonna try and find a intrpid fan but real quick question is im gonna be running 16' electric fan, a 12' electric, off road lights, trailer lights, should I upgrade to a 120amp alt?
Your stock should hanndle it, but upgrading is always better. I got a 140amp from autozone. I only got it because a lifetime warrenty. It would deffently be better to upgrade it for idle and low rpms
