carberator adjustment tool
Old Aug 12, 2008 | 09:23 AM
haberslober's Avatar
haberslober
Junior Member
Default carberator adjustment tool
i've been looking this tool but i've been hitting dead ends everwhere
Old Aug 12, 2008 | 11:19 AM
ratmandu's Avatar
ratmandu
I've seen a couple different ones at my local advance auto. Have you checked there?
Old Aug 15, 2008 | 01:07 AM
haberslober
Junior Member
Exclamation
i when to my local carquest near the college i'm attending and bought the last on their ever going to have on hand for a little under 20 bucks
Old Aug 15, 2008 | 06:46 PM
fwtc's Avatar
fwtc
i'm not sure what you mean by a carb tool. i only ever used a drill bit (choke), small ruler (float), and rock and roll for the mixture.
make sure the first two are set, turn the mixture screw in until it misses (lean). turn it out (count the number of turns) until th engine starts to roll (rich). divide that number of turns by 1/2 and turn it back in by that amount. the mixture is set. each choke ( motocraft, rochester, carter, etc.) uses a different size drill bit for choke adjustment.
what ever you do don't drop the bit down the intake, it will ruin your day to say the least!
the float can soak up gas if the coating on it cracks or wears off. check it see if it has, or feels heavy before you do the above mixture adjustments.
i love the 70's
Old Aug 15, 2008 | 08:34 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Here is a special tool store. http://www.etoolcart.com/on-linecatalog.aspx
