Trany problems
Old Aug 13, 2008 | 04:31 PM
megamoparman's Avatar
megamoparman
Junior Member
Default Trany problems
Hey guys, im new here but love anything mopar!! I just put my 93 dakota on the road and after a couple of days it just started to keep shifting between drive and second gear while i drive down the road. Is this a simple fix or am i in for a rebuild or trany swap??!!!
Its a 93 4x4 dakota 3.9 auto
with about 180,000 miles on it
Old Aug 14, 2008 | 08:08 PM
megamoparman
Junior Member
come on guys....i really need some help here!!!! some one has to know something bout my problem??
Old Aug 14, 2008 | 08:44 PM
Crazy4x4RT's Avatar
Crazy4x4RT
To me it sounds like it just needs an adjustment. There is an adjustment screw on the shift linkage. Loosen the bolt and move down the adjuster, untill its in postion. Then tighten back up.
Old Aug 15, 2008 | 09:49 PM
truck$'s Avatar
truck$
New Member
Cool trany problems
is it the three speed auto or the four speed?
Old Aug 17, 2008 | 08:38 PM
fwtc's Avatar
fwtc
93 only came in three speed with overdrive (4 speed). the 93 has a cable from the throttlebody to the throttle control valve on the tranny. adjust it like rt said and give it a try. if it's not quite right but better, any repair manual will give you the percise adjustments.
by the way, don't push the throttle control valve on the tranny foward with too much force or you might screw it, just enough to get it there.
