tranny service? whaa
what do u have to do to get the tranny pan to drop, also what freaking size are the crossmember bolts, i had everything on the stupied thing and it just kept spinning, really could use some help on this one guys!
The pan should just drop. There is one corner coverd by the exasht pipe. Some are closer than others. If it is in your way you might take off the tranny mount and jack up the rear of the tranny to give you a little more room. Dont forget to pull out the dip stick. As for the crossmember bolts. You didnt say 4wd or 2wd, or what year or engine size. I guessing 4wd v8 above 92 it is 9/16in and there is a nut inside the frame you have to hold while turning the bolt.
