Comp cams Thumper cams
Old Aug 27, 2008 | 12:09 AM
lnt118621's Avatar
lnt118621
Default Comp cams Thumper cams
Has anyone used the Thumper series cams. Also in the part description should it specify magnum vs LA or will it work for my 360 magnum?
Here is the jegs part #
249-20-603-9
Thanks
Chris
Old Aug 27, 2008 | 06:28 AM
408Ram's Avatar
408Ram
They do not inter change. this is for a LA block
http://www.compperformancegroupstore...Category_Code=
BIG ***** THUMPR™ for Small Block Chrysler 273-360 1964-2000
PART #20-603-9
Old Aug 27, 2008 | 04:44 PM
lnt118621's Avatar
lnt118621
Does anyone know of a cam with similar specs for the 360 magnum?
If not how but a good high performance cam?
Thanks
Chris
Old Aug 27, 2008 | 07:38 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The best place to look for parts is summitracing.com Type in the make and model (in your case it would be where the engine came from). I got my 5.9 from a 2000 dak. rt. so here are several cams, these will work for you http://store.summitracing.com/egnsea...rdSearch#rstop
