1991 Dak 3.9L back firing?
Old Sep 7, 2008 | 03:02 PM
LowClassicDC's Avatar
LowClassicDC
Default 1991 Dak 3.9L back firing?
my 91 dak is back firing alot now, it did it a few times here and there but now its getting really bad and sometimes stalls out the motor, any ideas on what that could be?
Old Sep 7, 2008 | 07:00 PM
codydakota's Avatar
codydakota
Have you checked the engine trouble codes? Could be the EGR valve, poor ignition timing, vacuum leak, damaged valve springs, or sticky valves, or a leak in the intake
Old Sep 7, 2008 | 10:39 PM
OneBadKota's Avatar
OneBadKota
I would check for dry-rotted vacuum lines first. I see that before the others.
.02
Old Sep 8, 2008 | 06:52 PM
LowClassicDC
well i hope its nothing serious cause ill just get a new motor, but ill check the vacum lines first, thanks for the advice guys
