96 dakota caliper pins
Old Sep 13, 2008 | 11:26 PM
96dakota4wd318's Avatar
96dakota4wd318
Default 96 dakota caliper pins
changing the brake pads for the first time on my 96 fwd dakota and found the bottom caliper pin striped not the pin but the housing ...not sure what to do now ..can anyone help
Old Sep 14, 2008 | 05:26 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You can get what is called a Heli-coil. You'll need to know what size threads the pin is.
Old Sep 15, 2008 | 03:04 PM
codydakota's Avatar
codydakota
If the heli coil won't do the trick, like it didn't on mine, caliper pins off a Ford full size work very nicely, they're a little larger, but as you screw them in, it will retap the whole and you'll be ready to rock and roll.
Old Sep 17, 2008 | 09:04 PM
fwtc's Avatar
fwtc
They are a known problem. Carquest has a bulletin for this repair. They have a kit with a drill bit, tap and coil for it. If this does not work, you have to replace the knuckle.
